I am a NEWBIE and will purchase a 2000-01 s-type soon need info on them!!!
Old Apr 11, 2007 | 09:28 PM
Envy337's Avatar
Default RE: I am a NEWBIE and will purchase a 2000-01 s-type soon need info on them!!!
If you are mechanically inclined, changing the fluid is not that hard.
Common problems with '00-01 3.0s.
Coolant leaks, Oil pan gasket leaks, vaccum leaks, coils.
It's a reliable car as long as you keep up with the maintanance.
Try to get a maintenance history from the owner before you buy. Look over the car for the mentioned problems.
Old Apr 12, 2007 | 12:54 PM
bigdreams05's Avatar
I have an 01 3.0 and so far it's been too good! Great car, but try driving it slowly over speedbumps to see if the ball joints have been changed. If they havn't, you'll hear a knock in the front suspension. Keep up with the maintenance. Look to spend about 350-400 bucks on the car the second you buy it. I spent about 400 bucks to change the coils, spark plugs, A/T fluid, engine oil, oil filter, air filter, pollen filter(about 2-3 weeks later), and a full coolant system flush! It hasn't given me any problems and runs great, but please make sure you use 93 octane gas and if the check engine turns on, check it out immediately!
Old Apr 14, 2007 | 12:43 AM
racerx82's Avatar
sounds good.....what do you think?
Old Apr 15, 2007 | 04:40 AM
Sounds good. About fair market value even a little below!
Old Apr 16, 2007 | 01:52 PM
Good info fast40... the ebrake while in neutral, then putting it in park will keep a lot of strain off the shifter... you can obviously feel how smooth the shifter will become. Then press the brake, put the car in reverse or park(whatever) and take the ebrake off. You're good to go!
H20boy
Dec 24, 2024 03:23 PM
SeanU
Sep 16, 2015 04:49 AM
rsperle
Sep 12, 2015 08:37 AM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
pocketrocket
Sep 3, 2015 07:44 PM
