If anyone still believes that the trans fluid is "for life"
Old Jul 24, 2012 | 07:30 AM
I think the magic additive was incorporated into the fluid.
Old Jul 24, 2012 | 12:17 PM
plums's Avatar
Wonder if anyone has tried "well the car is still alive, but the lifetime sealed transmission needs a transplant" on Jaguar USA.
Old Jul 24, 2012 | 01:23 PM
Spinall4's Avatar
Originally Posted by Staatsof
I've got go find the threads on the changing of the fluid as well as the ones on birdie chirp, chirp noise. Mine isa just over 30K and it's chirping more each day.
I have a friend with an Audi that I think uses the same basic trans and on those forums they talk a newer version of the fluid with different friction modifiers for solving the chirp.
Isn't the additive no longer available anyway?
It was so easy, the way I did it. The funnel I used is from Walmart. Just kept the funnel full of new fluid as it pushed the old out. I broke it up into 4 sessions with the motor running to push old fluid out. In between I gave it time for new fluid to work its way down.
The only time I had to get under the cars was at the end to check the fluid level and temp per the factory service manual.
I have my wife's sisters son come over to help with car stuff. He's 16 and just started to get insterested in working on cars so I bring him over to teach him the ropes. While we were doing it I asked him if he felt like we did $1000 worth of work ( figure 20 quarts of fluid at sixty each plus labor) and we just laughed beacuse it was so easy. If you wanted to you could also change out the filter at this time but I'm waiting on mine till I pull the valve body. Figure one afternoon worth of time with letting the cars temp cool off to check the fluid level.
Old Jul 25, 2012 | 09:08 AM
Staatsof's Avatar
You're talking about a complete fluid exchange right?
If at all possible I'd just like to put in the additive. I have just over 30K miles on the car so all new fluid and the labor involved seems like overkill not to mention expensive.
Old Jul 27, 2012 | 01:37 PM
gabrielduenas's Avatar
I had the fluid changed out about a month ago at 61K miles. Vehicle previously gave the old "lurch" problem
Bought this kit along with the necessary bolts and sleeve.
Oil change kit for 6HP26/28/32
I've driven the car about 500 miles since and am glad to say no more lurch.
Old Jul 28, 2012 | 10:24 PM
Amadauss's Avatar
I like the way they call it an Oil pan kit. Thanks for this link!
Old Jul 30, 2012 | 07:58 AM
thommo's Avatar
Default V6 ?
Does my model have the same pipework described that can be used to flush it through. It has the 2.5 engine so I wonder if it needs the same amount of transmission oil cooling. I would like to do at least a partial change at 9 years and 115,000 miles.
Jandreu
Jun 30, 2022 03:10 PM
1LowCat
Feb 23, 2016 07:19 AM
mrplow58
Sep 15, 2015 09:58 PM
chatmanx
Sep 11, 2015 07:17 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
