Issues when I hit 40 mph
Old Apr 10, 2016 | 05:23 PM
RickHamilton's Avatar
Default Issues when I hit 40 mph
I have a 2002 S type 3.0 and when I hit about 40mph the car starts to sputter a bit. It happens all the time. I did get a check engine light and it pointed to the catalyst converter. The car only has 67,000 miles. I recently had to replace a coil.
I don't want to spend $1,000 on coils and plugs plus $500 on a catalyst converter when it would just be guessing. Any suggestions?
Old Apr 10, 2016 | 05:31 PM
JagV8's Avatar
Get more data (via OBD). Look at fuel trims (hot engine) at idle and then rev to 2000-2500.
May be coil(s), air leak, etc - but the data will rule some out and save you a lot of money.
Old Apr 10, 2016 | 05:38 PM
I think the code pointed to the right catalyst. If I keep it at 2000 rpms when I drive it runs fine until 40mph. If I have it in park and Rev the engine it is fine.
Old Apr 11, 2016 | 12:24 AM
NBCat's Avatar
Post the DTCs here for advice. Guessing and just replacing parts may, or may not, not cure your situation.
Under no circumstances is the vehicle to be operated under conditions that cause the MIL to flash. A flashing MIL indicates catalyst damage
Old Apr 17, 2016 | 09:52 PM
It finally threw up a code and pointed to Coil #5. I replace 5 & 6 plus the 3 plugs on that side - runs like a champ!
xkeots
Mar 31, 2016 02:03 AM
Dean Kitching
Mar 30, 2016 02:53 PM
AJS57
Mar 27, 2016 10:31 AM
switcharoo
Mar 26, 2016 08:08 PM
NCJagman
Mar 25, 2016 12:58 AM
