Jaguar s-type 3.0 do not start the machine.
Old Jun 16, 2015 | 05:01 AM
Vaggelis Tzouganatos's Avatar
Unhappy Jaguar s-type 3.0 do not start the machine.
Dear members,
I have the JAGUAR S-TYPE 3.0 and i am not use it since 3 years.
I have allready put out the battery.
From now on i want to use the car often..
* i buy a new battery.
* i put 30 litre Petrol.
* i put new oil in machine.
* i have check the button "Reset fuel"
My problem is: While turning the ignition switch in starter, the car will not start, but only The sound of the starter.
Εxpect your answer.
I apologize for my english
Old Jun 16, 2015 | 08:04 AM
JagV8's Avatar
On top centre of dash, light (called PATS light) should flash (about every 2 seconds, I think) when car is off and key out. Does it?
If so, watch it as you try to start. What does it do?
Old Jun 16, 2015 | 08:54 AM
Dear JagV8
Thank you for your interest, I follow your instructions!
in my car The red led should flash every 2 seconds, when car is off and key out.
When i try to start the car, the light will come on permanently for 3-4 seconds and then turn off as much as i trying to STARTS the car.
i am waiting for your reply!!
Old Jun 16, 2015 | 09:00 AM
Mikey's Avatar
It sounds like the starter motor is turning but not the engine? If true, the starter motor needs to be repaired. If the engine is turning correctly, possibly there is no fuel pressure at the injectors.
Old Jun 16, 2015 | 09:24 AM
Thanks for your reply!!
The engine is turning but not start..! I will check the fuel pressure at the injectors and send you new message.
stanjag
Dec 29, 2024 08:26 PM
1964Daimler
Sep 2, 2015 11:41 PM
EastFalk
Aug 29, 2015 08:22 PM
mkrion
Aug 26, 2015 11:43 AM
NinoGrimace
Aug 26, 2015 05:15 AM
