Jaguar S type lock lug key
Old Jul 26, 2009 | 01:26 PM
phd12volt's Avatar
https://www.jaguarforums.com/forum/s...ad.php?t=19276
this was just talked about within the past couple weeks, searchy searchy!
Head down to your local tire shop and see if they can remove them for you. There are ways of doing it where it wont mess the wheels up.
Old Jul 26, 2009 | 02:58 PM
Thermo's Avatar
Veteran: Navy
Waylon, what you will need to do is to get your hands on a 19mm impact socket (not a standard socket, but a black impact wrench socket). Then you will put this socket in front of the lock on the wheels and using a hammer (preferable a BFH), you will end up beating the socket on to the locking lug nut. Then you use a 1/2" breaker bar to get the lugnut loose. Repeat for the other wheels. From there you will end up getting 4 new lugnuts to replace the current locking lugnuts. That is pretty much what the tire shop is going to do.
jdzubas
Oct 4, 2015 09:14 AM
nelsonht
Aug 30, 2015 06:01 AM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
