Knock Sensor location on 2004 4.2 NA
Old Mar 2, 2020 | 11:06 AM
Brian H Smith's Avatar
Default Knock Sensor location on 2004 4.2 NA
Ok, wife's S type threw the P0327 code (low voltage knock sensor bank 1). Where is this thing located. Looked at the pictures of the 4.0, should be outside the plenum between the middle injectors. it isnt there. Is it under the plenum? Added pics so you would think I was insane...
Thanks,
Brian Smith
Old Mar 2, 2020 | 11:34 AM
AT_STR's Avatar
Hi,
knock sensors are under the intake manifold just like in the SC version only under the supercharger. You must remove the intake manifold to get to them.
Old Mar 2, 2020 | 12:48 PM
Well, crap. Thanks, that is not what i wanted to hear.
Oh well.
Brian
Old Mar 2, 2020 | 01:29 PM
AT_STR's Avatar
Believe me, it's better to remove the intake manifold anyway than a supercharger . Probably the gaskets are worth replacing by the way.
I recommend downloading Workshop Manual - there is a nice description of what and how with pictures .
Adam.
Old Mar 2, 2020 | 01:43 PM
I would replace the intake gaskets anyway, false economy not to...
Brian
Old Mar 2, 2020 | 03:15 PM
JagV8's Avatar
last thing you want is a pesky air leak!
Old Mar 6, 2020 | 05:45 PM
jaidank's Avatar
On my (departed) x308 (3.2 V8) I was able to replace a knock sensor without removing the intake manifold.
Check if you can see it down between the manifold pipes.
vincek
Nov 28, 2022 02:12 PM
Jdel
Oct 22, 2018 09:44 PM
Carnival Kid
Apr 1, 2018 12:39 PM
DavidN
Sep 17, 2016 09:12 AM
wordman
Feb 1, 2013 11:12 AM
