location to add freon...
Old Feb 14, 2010 | 02:52 PM
frankmarroquin's Avatar
Default location to add freon...
Where is the little nozzile where you add freon located on my 2000 Jaguar S Type with the 4.0. Thanks guys
Old Feb 14, 2010 | 11:41 PM
dperry's Avatar
drivers side behind front wheel
Old Feb 23, 2010 | 07:04 AM
Thanks apprecite the help... I'll check it as soon as I get a chance.
Old Feb 23, 2010 | 08:07 AM
Jagucat's Avatar
Is it still Freon you use in the system? R134a is what they run on over here and not mixable. The connector you are after is on the pump itself, low down. You may have to jack up the corner to get better access. The other connector is up top at the other side above the receiver/ drier. One low pressure, the other high.
Old Feb 23, 2010 | 07:50 PM
JAG06's Avatar
It's not worth it to do yourself. Make a mistake with the hi side pressure line and you could get hurt big time. This is based on you doing this the first time yourself. To much to risk if something goes wrong. Also remember if it needs freon it leaked from some where. Freon refills only, without checking and repair the real problem will bite you in the rear down the road.
Rivguy
Nov 13, 2022 02:55 AM
TXJagR
Jun 20, 2016 01:02 PM
danpop
XJ40 ( XJ81 )
Oct 31, 2015 10:25 AM
bowhunter72
Sep 21, 2015 10:14 PM
chatmanx
Sep 11, 2015 07:17 PM
