Location of BCM module in S-Type R (RHD)
Old May 6, 2017 | 07:00 AM
Michal's Avatar
Question Location of BCM module in S-Type R (RHD)
Hi all,
My car suffers from battery drain. Had electrician investigate it and he is 95% sure it's BCM. Tested all modules, even removed Satnav and after disconnecting BCM the drain dropped to normal values.
Now, I would like to check the numbers on my BCM and try my luck with eBay before heading to the *******. The only problem is I can't find where the bugger is located. Not sure if LHD and RHD cars are different in this respect, but any help would be greatly appreciated.
Old May 6, 2017 | 07:07 AM
JagV8's Avatar
First grab the workshop manual and figure the Jaguar name for it then it also says where.
Old May 6, 2017 | 08:08 AM
jagstuart's Avatar
http://ww2.justanswer.com/uploads/n9...120130_loc.gif
Old May 6, 2017 | 11:21 AM
car5car's Avatar
You will not see it until you remove bracket, it is attached to. Remove right cover in trunk, you'll see parking brake module attached to big bracket, BCM is on another side of bracket.
