Location of ODBII port?
2001 S-type 4.0
Hi, dumb question...I took a quick look for my ODBII port on my car. Didn't see it...is it covered by a cap of cover of some type? Where is the exact location?
Btw, it is a left hand drive car.
Cheers,
gerry
Cheers,
gerry
It's under the bottom edge of the lower dash panel, drivers side, under and slightly left of the steering column, now I'm thinking of my UK spec car, so the LHD may not be a mirror image. But if you look up under the lower dash from floor level you should be able to spot it.
BTW - No cover, just a black plastic connector with metal inserts for the contacts.
jimforrest (uk)
Feb 28, 2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
Jan 14, 2016 11:32 AM
