lower imt o ring replacement
Old Aug 8, 2012 | 11:39 PM
mikewv100's Avatar
Default lower imt o ring replacement
I just had to replace coil pack on back passenger cylinder (5) on my 2003 v6. I tried for hours and could not get the brake vacuum hose off of manifold. I lifted it up high enough to change plug and pack and it is running., but there was oil at bottom of coil pack on top of plug. I understand from reading that it is most likely imt o ring. My question is this. Can lower imt o ring be replaced without removing or loosening manifold. Wife does have small hands and can help.
Thanks in advance.
PS I got in running and 20 minutes later the drivers window regulator plastic clips broke and my window fell to bottom of door. You will never get bored with this car!!!
Still a joy to drive.
Old Aug 9, 2012 | 05:43 AM
joycesjag's Avatar
Mike you might find this useful:
https://www.jaguarforums.com/forum/s...ics-faq-32135/
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
