lugnuts once again
Old Mar 31, 2011 | 08:42 AM
Biggbore's Avatar
Default bait
Now I feel like bait, & you know how that work's out for the bait
Old Mar 31, 2011 | 11:11 AM
Staatsof's Avatar
Originally Posted by norri
Good man! We needed a guinea pig. When are they due to arrive? We will expect a full report, pictures and perhaps a how to fit lugnuts video.
Yeah, I'll second that. Show us us your nuts. ...
Seriously, if these are stainless steel and nothing looks weird about them I might buy a set too!
Old Mar 31, 2011 | 11:42 AM
JOsworth's Avatar
Originally Posted by MDJag
try these...DORMAN Part # 611117 from Rockauto.com
10 for $2.44 each
I have 2 boxes of 10 of these Dorman lugnuts from Rockauto...But now I don't have the car....
Heck PM me an offer.... I have no use for them...
Old Mar 31, 2011 | 08:26 PM
Spitfire's Avatar
I pulled the trigger too and bought the ones Grn03STR posted. Not due to arrive for about 2 weeks though. I'll report back in once they arrive to let you guys know.
Old Mar 31, 2011 | 08:48 PM
Grn03Str's Avatar
I did end up ordering a set but im in Canada so im sure you guys will get yours first
Old Apr 5, 2011 | 07:05 PM
Spitfire's Avatar
Dammit. My lugs came in today, but they're the two piece, exactly what I've got on the car already. Why o' why didn't I ask before I purchased if they were one or two piece. They are nice however and are brand spanking new.
Old Apr 5, 2011 | 07:37 PM
Grn03Str's Avatar
Aww man so sorry for posting that link. I thought the OEM Toyota nuts were solid 1 piece. Mine should be here tomorrow...guess ill be using them till they fall apart or start making noise.
Old Apr 6, 2011 | 05:02 AM
  #28
JOsworth's Avatar
Ummm... Cough...Cough.....
Psst... BTW I know how to send stuff to Canada.... Yikes.... I'm gonna get in trouble....
Old Apr 6, 2011 | 09:22 AM
Mikey's Avatar
I think pretty well everyone knows where their local post office is........
I've got the solid Dorman nuts on mine, so far so good. I can't help wondering if the problem with the OEM nuts is not really with the ***** lugnut wrench that is supplied with the car. I was surprised at how light weight it is and equally how easiliy it deformed the first time I attempted to loosen the nuts on a wheel. I ended up using an old crossbar wrench I've had since the 70s and never damaged another one.
Surely Jaguar must know of the field problems with the nuts?
Old Apr 6, 2011 | 10:29 AM
  #30
Jon89's Avatar
No, the fault is not with the lug wrench. Two-piece capped lug nuts are destined to fail regardless of who makes them. I've had numerous factory sets over the years. Didn't matter who built the vehicle or made the lug nuts. If they were two-piece, they eventually failed. Some quicker than others, though....
Old Apr 6, 2011 | 11:45 AM
  #31
JOsworth's Avatar
Yup^^^^^
The cap eventually loosens up from the solid nut it is attached to. My tire shop called it "swelling"...
The Chrysler LX(Charger, Magnum, 300) folks have the same issue... I have 20 of the Dorman part for the Chrysler sitting on the work bench now.. Yet the Dodge Caravan has solid lug nuts.... Who thinks of these things....
Old Apr 9, 2011 | 12:15 PM
  #32
Biggbore's Avatar
Default buying under the influence
Well they are two piece with ss cover ,don't look good. The wife slaps the back of head & said if she catches me BUI again there will be two more useless nuts around here SEAYA!!
Old Apr 9, 2011 | 05:24 PM
  #33
Staatsof's Avatar
Default Just to clarify
When you guys start talking about 2 piece nuts let's remember that even the ones WO the SS slip-over covers are two piece because the washer floats on the nut.
So maybe we should call the OEM onces three piece nuts?
Old Apr 9, 2011 | 06:28 PM
  #34
JOsworth's Avatar
Since we're splitting hairs here.. Or is that splitting nuts....
They are really 4 piece nuts.. At least mine were.. Nut, slip-over cover, metal washer backed by a nylon washer....
Old Apr 10, 2011 | 09:08 AM
  #35
clubairth1's Avatar
Community Influencer
I have no rust on the Dorman lug nuts either? I have them on both the STR and the Lincoln. Had them 15 months or so but I don't live in a salt area. They sure look like stainless steel?
Old Apr 10, 2011 | 10:22 AM
  #36
Jon89's Avatar
The best terminology for the lousy "two-piece" lug nuts is actually "acorn-style lug nuts". I heard a mechanic use that term back in the 1990s and it sounded right on the money to me since acorn seeds easily separate from their shells when they ripen and fall off the oak tree, much as these lousy lug nuts separate after they've been removed and reinstalled enough times. Another appropriate term is simply "capped lug nuts"....
Old Apr 11, 2011 | 06:38 AM
  #37
maxthrottle's Avatar
Pep Boys has the one piece heavy chrome plated acorn style lugnut for Toyota, made by White Knight. They fit perfectly and look great. $6 for a pack of four.
$30 for the complete 4 wheel redo. You will need a new 7/8" lugwrench they sell that for less than $10, much nicer than the flimsy OEM unit.
Old Apr 11, 2011 | 07:06 AM
  #38
Staatsof's Avatar
Default My STR DOES NOT WEAR NYLONS!
SNut, slip-over cover, metal washer backed by a nylon washer....
I'll go look again but nylon washers? Doesn't even make sense. Who puts 80-90 ft lbs on a nylon washer and expects proper results?
OK I just checked. No Nylon washers. That must be a "drag" option ...
Old Apr 11, 2011 | 07:59 AM
  #39
JOsworth's Avatar
Hmmm... Wonder if the R has different nuts... I know it's got more *****...
Ooops... I'm gonna get banned......
Here is a picture of the factory lug nut that was on my 05 3.0. Notice the black nylon washer between the metal one and the shoulder of the lug nut...
Old Apr 11, 2011 | 08:06 AM
  #40
JOsworth's Avatar
Default NOT Acorn Lugs....
Umm, don't get Acorn style lug nuts... They are not correct.. Acorn nuts are capped (closed top) with a taper seat.. The Jaguar lug nuts are mag type / sometimes called "shoulder" or "washer seat".. Please see the chart below.
Had to be careful with the Chrysler as well. People think the 300 has standard Acorn lug nuts as well... But they use "bulge" seat lugs... Using standard can cut into the wheels.
