Milky Headlites
Old Dec 28, 2009 | 04:26 PM
LinksXK8's Avatar
Default Milky Headlites
Does anyone know of anything to clear my headlites without buying new ones . I can't stand them any longer 2000 s type Thanks
Old Dec 28, 2009 | 04:52 PM
MySType's Avatar
There was a thread that someone posted about that very question, they showed before and after pictures. Very informative.
Old Dec 28, 2009 | 04:55 PM
MySType's Avatar
Default Clouded Headlights
https://www.jaguarforums.com/forum/s...ght=headlights
Old Dec 28, 2009 | 06:58 PM
LinksXK8's Avatar
Thanks for the thread, I have already tried the polish, but mine are so far gone it didn't work. I put some silicone spray on & that cleared them for about a day.Maybe I'll try to spray them with a clear hi gloss plastic paint .I don't know, but I don't have anything to loose Thanks again
Old Dec 28, 2009 | 07:53 PM
joycesjag's Avatar
goto the exterior detail section of jaguarforums there are quite afew threads about headlamp detailing. I personally would not clear paint them until they are buffed out. I have used the 3m headlamp cleaning kit and it has made our headlamps clear as new. The product is available at any big box autoparts store.
Old Dec 28, 2009 | 08:07 PM
+1 on JJ's comments.....check out the detailing section for a really good how to c/w vids on the subject
Old Dec 29, 2009 | 09:36 AM
badmojo's Avatar
If there really bad you may want to start with some 600 grit sandpaper and then go to about 1200 or 1500 grit before polishing and buffing them. Then I would go for some of the clear plastic ( almost like a thick food wrap ) headlight protectors.
Old Dec 29, 2009 | 10:13 AM
Thermo's Avatar
Veteran: Navy
I use some stuff called 3M Perfect-It II. It is a liquid rubbing compound. But it works wonders on headlights and whatnot. I will admit that it takes a little bit of elbow grease to clear up some of the more badly scratched headlights, but it does work. I use it periodically on my Jag. The other nice thing about this product is that it is also good for chrome, glass, and even paint. It is a all-for-one product. I use a cotton cloth to apply and remove the product. The only problem with the product is that it is a little bit difficult to find. BUt, if you go to a store that sells automotive paint by the quart/gallon (ie, not your local auto parts store), they normally carry it. I think they have upgraded the formula and they are now calling it Perfect-It III. I swear by the stuff.
Old Dec 31, 2009 | 09:04 PM
LinksXK8's Avatar
Thanks for the threads ytube is great! when I tried to polish mine with the, I think it was Mequiars head lite polish it only had a polishing cleaner & polish "no sanding"& I had no luck @ all I cleaned & polished for about an hour with the little drill tip that came in there kit. but after seeing the detailing & sanding on youtube I think when it warms up again I'll try the sanding method then polish. Thanks again for all the leads
Old Jan 1, 2010 | 10:59 AM
reddrawf's Avatar
Might want to check out these options too:
http://www.autogeek.net/headlight-lens.html
firestar
E type ( XK-E )
20
Sep 16, 2021 09:08 AM
TreVoRTasmin
Aug 12, 2015 11:09 PM
Panelhead
Aug 8, 2015 08:35 PM
sleeptress
Jul 16, 2015 12:24 AM
sleeptress
Jul 15, 2015 07:36 PM
