Misfire
Old Nov 18, 2009 | 10:41 AM
tbird6's Avatar
It's a well known problem. Please search the forum. Many detailed posts on what to look for and what to replace. Not a hard job for a DIY guy!!
Old Nov 18, 2009 | 11:44 AM
JOsworth's Avatar
Yes search... But what ever you do, ignore the comments about using silicone sealant on the coil packs! Unless you also read the comments from a user called "BRUTAL" where he explains why that is not a good idea.....
Old Nov 18, 2009 | 11:46 AM
JagV8's Avatar
Don't neglect it - raw fuel is being burned in your cats and may destroy them. Not worth the risk. By the time the CEL (MIL) is on, it's a bad misfire.
Old Nov 18, 2009 | 12:33 PM
Jon89's Avatar
Check my thread called "Misfire Issues" which I believe was last updated today....
As previously mentioned, the Jag tech named "Brutal" has offered a number of ideas that are well worth considering in an effort to reduce these misfire issues (especially on cylinders 1, 3, and 5 on the passenger side of the car here in the U.S.), many of which seem to be caused by blow-by oil getting into various engine components where it doesn't belong. One of the recommended steps to take is to consider replacing the two original yellow-colored Intake Manifold Tuner O-rings with the new-and-improved green-colored O-rings. The original yellow O-rings are not large enough and over time, they'll break down and begin allowing oil to seep through. The new green O-rings are larger and apparently better engineered. They stop these particular leaks immediately....
Rick (known as "joycesjag" here on the forum) changed his O-rings early this year and put an end to his particular oil seepage problem. Perhaps he'll chime in here and give you some additional pointers....
Old Nov 18, 2009 | 12:48 PM
JagV8's Avatar
Er... which engine? 2.5? 3.0? 4.2? SC? (Sounds like the 3.0 just from the fault!)
Old Nov 18, 2009 | 03:17 PM
tbird6's Avatar
Good point JagV8! I forgot to ask that!
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
