My Jag has more leaks than the White house
Old Jun 12, 2020 | 01:29 PM
oldtvman's Avatar
Default My Jag has more leaks than the White house
good afternoon,
Just kidding about the title, but I'm replacing some of the hoses on the s type r and the one hose looking at the car from the front on the left side of the radiator is really a tough challenge.
Is it necessary to take the bumper off to get in and change it out?
thanx
Old Jun 12, 2020 | 03:34 PM
scottjh9's Avatar
Originally Posted by oldtvman
good afternoon,
thanx
If it is the same one i did, take the wheel and plastic liner off....is it the one that goes down along the radiator to the other coolant pump
Old Jun 13, 2020 | 04:10 AM
jya's Avatar
jya
Hard to know which one you're referring to without a picture. If your'e talking about the long thin hose that goes down to the SC coolant pump area, bumper removal is not necessary. However if your car still has the original hose clamp still attached to that hose you will need a compact hose clamp removal tool (one with the cable extension) to be able to easily release that clamp.
I would also change the short larger diameter main radiator hose as well while your'e at it as you will need to probably remove this first to get to the clamp anyway. Also seriously think about changing the short larger diameter engine coolant inlet hose (I think part no AJ8873) as this does cop most of the heat; this does need a bit of stuff to be removed before you can get to it.
While your at it lol change the notorious valley hose (throttle body return hose) as well if it hasn't been done yet....
Old Jun 13, 2020 | 07:02 AM
oldtvman's Avatar
Thanks,
I can see it with the lower grille removed but can't get at it, I have the old on off.
Old Jun 15, 2020 | 11:02 AM
clubairth1's Avatar
Community Influencer
I would plan on changing ALL of the hoses. When I had my old 2005 STR the only problems I had were coolant leaks and I fixed them one at a time. Would have been cheaper and far better to just plan on changing them all out at once.
I am sure your aware of the dreaded under SC hose the STR's have? That's a cheap hose that can cause a very expensive repair or engine destruction!
With the age of our cars it definitely needs replaced.
Crackerbuzz
Jul 30, 2018 02:51 AM
Dan R
Apr 3, 2018 08:59 PM
legendary layla
Nov 17, 2017 07:12 AM
SparkyGage
Jun 14, 2015 08:34 AM
o1xjr
May 20, 2014 04:54 AM
