NEW TPS caused havoc !
Old Aug 15, 2020 | 09:22 AM
jaimster's Avatar
Talking NEW TPS caused havoc !
I thought maybe by getting a NEW TPS sensor may improve idling - BIG mistake again lol .... BABABUI my TB ,, it had actually been running decent much better than before .. NOW i got the dreaded code P0122 throttle /pedal .....circuit low which is with the OLD one back on ,, got rid of the NEW one ( got more codes with that one)
whatever damage has been done .. getting NOW DSC not working , engine fault ,, limp mode eally..
read check power on fuse F18 .. no power at all .. I just ordered a used TB from ebay which I believe it should be plug and play IF no damage was done to the ECM ..
questions is there a proper way to install a TPS sensor and how to check the leads - I have electrical wiring OY positive , GB negative OTHER two wires INPUTS .?
Old Aug 18, 2020 | 04:48 AM
Datsports's Avatar
There is a detailed how to calibrate the TPS posted in the S type stickies.
although I’ve never had to , it states It is necessary after battery disconnection.
I wonder if this could help.
Old Aug 18, 2020 | 08:38 AM
jaimster's Avatar
thanks Datsports I have tried that several times .. still NO luck i got a feeling i may shorted out the TPS (1,2) If i m lucky hope didn't damaged the ECM !!
I m getting a used TB from ebay thursday or friday .. we'll see that goes !
kaotikd
28
Jun 2, 2020 12:21 PM
greenforest56
Nov 16, 2017 04:17 PM
juliovega914
Oct 8, 2013 02:34 PM
reddog120247
General Tech Help
Apr 6, 2012 07:35 PM
Bileeg
Sep 23, 2007 04:03 PM
