No Heat DCCV and control head
Old Nov 5, 2009 | 12:53 PM
tbird6's Avatar
Sorry to hear all your troubles!! Unfortunately you got just about the worst year possible for the S Type. No way around the DCCV. I do question that the DCCV can blow the head unit out? I know for a fact it does NOT on the Lincoln LS but the cars do use much different electronics. I would change the valve first and see if the heat situation improves. The DCCV is MUCH cheaper than a new control head. Which do you have? Navigation or not? The navigation version is very expensive. Also look on EBay for a used control module. I have seen several of the non-navigation versions for pretty cheap prices.
Old Nov 5, 2009 | 07:31 PM
Bob Smith's Avatar
I don't know for sure, but there are definitely some posts in the archives that state that a faulty DCCV can cause an Air Con Module to fail.
In theory, there's no reason why you couldn't bypass the DCCV. The tricky part might be incorporating a splitter so that you could still flow coolant to both heater core pipes... plus you'd probably want a manual valve in-line so that you could close it off in the summer when you didn't want heat. I've seen at least one post on another forum (might've been Jag Lovers) where someone's mechanic did this. My 54 Jag has a manual heater valve switch under the bonnet that does the very same thing, when you want heat you need to open the valve, when you don't want it, you need to close it off.
H20boy
Dec 24, 2024 03:23 PM
Steviedee1st
Nov 28, 2023 06:32 PM
02jagstype
23
Oct 23, 2022 07:03 PM
OkieTim
Sep 8, 2015 04:48 PM
tberg
Sep 7, 2015 07:32 AM
