O-rings and shim for big input hose of DCCV valve?
Old Apr 27, 2017 | 03:46 PM
webbeing's Avatar
Default O-rings and shim for big input hose of DCCV valve?
Hello,
On a 2000 S-type V8 4.0, does the bottom hose (the bigger than the two top outlet hoses) to the DCCV valve has o-rings and shim? From some excellent repair procedure that I read, the two smaller outlet aluminum hoses have o-rings and shim which I found when took them out. But I didn't see any o-ring or shim for the bigger bottom hose.
Thanks.
Old Apr 27, 2017 | 11:26 PM
abonano's Avatar
Originally Posted by webbeing
Hello,
Thanks.
The larger hose has the o rings inside the fitting.
Hope this helps.
