O2 Sensor obsoleted
Old Sep 4, 2019 | 09:58 AM
tonykart's Avatar
Default O2 Sensor obsoleted
I have a 2002 S model with the 4.0 v8 engine. The oxy sensor has been obsoleted by Jag and is misreferenced on the net and with the usual autoparts stores. This is the upstream sensor. It has 2 wires and a square connector. What is an acceptal replacement? Anything plug and play?
Old Sep 4, 2019 | 10:55 AM
wydopnthrtl's Avatar
rockauto shows 6 upstream 02's for your car. Those are not correct?
Old Sep 4, 2019 | 11:26 AM
tonykart's Avatar
I just looked at those, all have the wrong connector and more than 2 wires.
Old Sep 4, 2019 | 11:59 AM
leaping cat's Avatar
Denso 234-4046
Old Sep 4, 2019 | 12:12 PM
kr98664's Avatar
Something ain’t right. 2002 wiring diagrams here:
http://www.jagrepair.com/images/Auto...x2032002en.pdf
See figure 03.1 for the V8. It shows all four sensors each have four wires. That’s how my ‘02 V6 is.
On each sensor, two wires are for the heating element and the other two are for the oxygen sampling.
Has your car been modified? Do you have any fault codes? I can’t imagine the computer is happy with only two wires present at the oxygen sensors.
Old Sep 4, 2019 | 12:21 PM
tonykart's Avatar
the denso 2344046 has a round connector and 4 wires, wrong part entirely. Parts geek calls that out for a ford truck.
My car has never been modified and both upstream sensors have a square plug with 2 Yes 2 wires. The plugs have 4 pin holes but only 2 are used.
Fault code is P0153
Old Sep 4, 2019 | 12:23 PM
tonykart's Avatar
Jag calls the part a "XR86938" and is obsolete according to our local dealer this morning.
Old Sep 4, 2019 | 12:35 PM
S-Type Owner's Avatar
Is this what you are looking for?
https://www.rmeuropean.com/Products/XR86938-MFG14.aspx
Old Sep 4, 2019 | 12:36 PM
tonykart's Avatar
I just looked at a bunch of the "XR86938" crosses and they have 4 wires and the wrong plug.
Old Sep 4, 2019 | 12:38 PM
tonykart's Avatar
that's where the numbers point me but that bosch is 4 wire and a round plug.
Old Sep 4, 2019 | 12:39 PM
tonykart's Avatar
whats the dif between a 3 wire and a 4 wire, cuz there appears to be 3 wire with the correct plug.
Old Sep 4, 2019 | 12:53 PM
tonykart's Avatar
nevermind, they almost all look like 4 wire, but my plugs look like the square downstream plugs, not the round one.
Old Sep 4, 2019 | 01:29 PM
motorcarman's Avatar
It would help to know what part of the WORLD you are located and the MARKET trying to obtain parts for.
Jaguar has many different parts for the various markets they sell cars. Many different Countries have different emission regulations.
bob
Old Sep 4, 2019 | 01:31 PM
You might try searching for a Lincoln LS V-8 sensor of the same era, as there was a more significant commonality of parts and systems with the x200, S-type.
Old Sep 4, 2019 | 01:36 PM
tonykart's Avatar
Am in the USA, have looked at probably 100 sensors so far, none are 2 wire with square plug. I see the plug on some downstream units but not on upstream like mine, and I dont think mine are heated as there are only 2 wires.
Old Sep 4, 2019 | 01:38 PM
tonykart's Avatar
have looked at the lincoln parts, see 4 wires and round plugs
Old Sep 4, 2019 | 01:43 PM
tonykart's Avatar
Oh by the way, car still runs great, just throwing engine light.
Old Sep 4, 2019 | 01:49 PM
You might want to have a physical look at one or two of the suggested parts, as it appears that most (if not all) of the on-line vendors are using a stock pic of the part. If the pic is incorrectly cross-referenced by the manufacturer or distributor, incorrect info travels fast on the web.
Old Sep 4, 2019 | 01:55 PM
tonykart's Avatar
what if I chose one that is what is mostly used,plumb in the data wires and eliminate the heater wires. Will the sensor still send correct data to the ecu? It is appearent that one will have to be modified in as I can find nothing that is correct plug and play either from Jag or any other cross. I can't find any upstream with the correct connector.
Old Sep 4, 2019 | 02:15 PM
I'd do two things before proceeding.
1. Look at how quickly the 02's swing. Is that in spec? (does reality match the P0153 code?)
2. Physically pull one and inspect the car side connector. Look to see if its a genuine Jag connector (OEM was most likely FORD) and that something odd wasn't spliced in.
