Oil leak problem..
Old Oct 18, 2009 | 01:01 PM
kblood's Avatar
Default Oil leak problem..
I just got the inspection for my jag 2weeks ago and a car shop guy said my jag has some oil leaks which is little bit. So they recommended me to get car wash to find where it is leaking and how severe it is..
so I have a question!!
How much it usually cost..?
I know it depends on how bad it is but as the car shop guy said, i think it would not be bad...
Old Oct 18, 2009 | 01:15 PM
Thermo's Avatar
Veteran: Navy
kblood, which engine (3.0L or 4.0L, or diesel)? The 3.0L engines are known for leaks from the oil pan and getting out the oil pan is a real PITA. Read that is many hours of labor. So, a $20 gasket replacement will cost you around $500. Some fixes are easier than others.
If you have someone wash the engine, stand by. The newer engines do not like having water forced on them and the engine will more than likely start tossing all sorts of codes. I personally would not use anything over a garden hose. Even then, try to avoid things like the tops of the valve covers. You can clean the engine yourself. Go get yourself a can of "Gunk" (engine degreaser) and get the engine nice and warm (drive for about 3 miles or so). park the car, spray the Gunk on the engine (watch out for spraying directly on wiring and other electronic parts), let sit for a few minutes and then hose off. That should remove most of what you will need. From there, crawl all over the engine to see where any oil may be left, drive the car another say 50 miles and do another inspection of the engine. Where you see the oil starting to leak is more than likely your source.
Old Oct 18, 2009 | 01:55 PM
kblood's Avatar
Default Thanks for your reply!
hm, my jag is v6 3.0L gas.
I ve read your detailed reply thankfully.
so as you said,, it would coust at least 500$?...
I am the one who just got my first car which means,, I know nothing about car.. so I am an uncomfortable of doing someting for my car myself..but..I will try!! thx
Old Oct 18, 2009 | 04:32 PM
Kblood,
I'd take the under engine pan off and get under the car, supported safely, and clean off all the oily bits from underneath.
Then give it a run to get warmed up and park it over a clean piece of cardboard and try to find which area is leaking then get underneath again and see if you can find exactly what it is.
Danielsatur, it doesn't sound like Kblood's first language is English, so cut him some slack!
Old Oct 18, 2009 | 06:43 PM
JOsworth's Avatar
MacGyver's head is so far up his large intestine he wouldn't understand that...
Old Oct 18, 2009 | 08:09 PM
kblood's Avatar
thx guys..
i'd rather to take my car to the jaguar dealer.
Old Oct 18, 2009 | 08:20 PM
cleveland's Avatar
The advice given by Norri is a good way of generally locating a leak. If the leak appears to be from the oil pan gasket, I would first try retorqing the bolts, and also add some oil stop leak. There are a number of well known brands of stop leak out there.
jdzubas
Oct 4, 2015 09:14 AM
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
