Ok need a little code advice P0171 & P0174
Old Dec 21, 2012 | 11:33 AM
joycesjag's Avatar
Originally Posted by devo357
Good point, is the engine compensating the lean condition with more fuel? and if so is that amount of extra fuel enough to kill the catalyst?
Eventually as to how fast is anyones guess. I would say that they will not die overnight, but I am assuming.
If you have not touched the airbox prior to throwing the codes, again I would purchase a can of MAF cleaner and start there.
I hear you on the other vehicle.
Your welcome for the write ups. I hope they help. As you see i have been around our S Type once or twice....literally.
Old Dec 21, 2012 | 11:34 AM
devo357's Avatar
Oh man I completely forgot about that!
Old Dec 21, 2012 | 11:44 AM
QuartzSTypeR's Avatar
The reason I ask is that I am in the process of replacing the ball joints, tie rods and ends with a new rack and control arms on our extra car. so I am looking at least a few days before I can get the Jaguar sorted out.
Thanks Joycesjag for the great write ups I have them all printed out on my desk!
Running lean means running hot. Too hot=damaged parts, whether it be your valves or cats or what-have-you. With the codes you have combined with the absence of obvious running problems, it is highly unlikely that it will lead to anything catastrophic in a short time frame. I would say its best to address it sooner than later, but a few days/couple weeks likely isn't going to hurt anything long-term.
Old Dec 21, 2012 | 12:21 PM
JagV8's Avatar
Originally Posted by Robinb
Hmm, that's more complex than I thought. My peasant-level Ultragauge just shows LTFT for Bank 1 and Bank 2. What device would I need to break out the LTFT matrix into values at idle and 2500 rpm so I can see how fast each set is closing in on zero?
Usually you can see the values in real time, in which case you're seeing the values at the current rpm. So just look when the car is idling (warmed up) and then rev to about 2500 and look again as you hold the revs.
It doesn't have to be exactly 2500. The point is to have lots more air flow so that any leak is likely then to be a smallish part and you can compare with the idle figure when a leak will make a relatively large impact. If you don't see quite different trims you almost for sure don't have an air leak, or at least not a typical one.
The fancy tool can track trims at various rpms but you can do it by hand.
If you appear to have an air leak, some cautious spraying of propane at idle will make the trims move almost instantly (and you may hear the engine note change).
Old Dec 21, 2012 | 12:28 PM
JagV8's Avatar
Yes it adds fuel. There's a good "quiz" about lean codes in General Tech. If you're lucky a leak is smallish and the extra fuel just compensates, so the cats are fine. Er... if you're lucky.
The codes flag when the extra fuel it's having to add is rather a lot (over 25%)!
Really it's a good idea to have a look at trims every now and then as even 10% is a real worry.
BTW, misfires often trigger lean codes (think and you should see why).
Old Dec 22, 2012 | 08:29 PM
joycesjag's Avatar
Darren any update?
What did you find?
Old Dec 23, 2012 | 10:08 AM
devo357's Avatar
UPDATE
Ok after spending most of the weekend looking for vac leaks and not finding any I broke down and bought a new MAF and Bam! its fixed!!! no more codes. I guess I got lucky I tried to clean it with no luck so I just gave it a shot and bought a new one.
Dean
Old Dec 23, 2012 | 10:11 AM
  #28
devo357's Avatar
RICK
LTFT was good wish I would have checked it first! that was really good advice. What a friggin hassle this has been I hate chasing down vac leaks!!!!!!!!!!!!!!! now off to get the truck done need it tomorrow.
Thanks to everyone that chimed in!
Dean
Old Dec 23, 2012 | 11:20 AM
joycesjag's Avatar
congrats.
clubairth1
30
Sep 3, 2025 04:38 PM
Bob Gelston
Sep 14, 2015 11:08 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
