Ooops, I broke coolant sender. Now what?
Old Apr 6, 2013 | 09:45 AM
BmwR60's Avatar
Default Ooops, I broke coolant sender. Now what?
Hello.
While attempting to change the serpantine belt on my 03 S-type 4.2, the wrench slipped off, hit and broke the H2O sensor. The car now runs in limp or "restricted performance" mode and showing code PO117. I can't see how the sensor comes out as it doesn't appear threaded. As well, do I need a special tool? Once out, can I buy just the sensor? Looking online it is unclear as to if you can buy just the sensor or you must replace the entire thermostat housing. Am I opening a can of worms here as a DIYer?
Thanks.
Old Apr 6, 2013 | 10:40 AM
Six Rotors's Avatar
Well if you slide off the rubber boot which covers the lower part of rhe sensor all will be revealed--the sensor is indeed a screw fit in the plastic housing and can be removed using a 19mm wrench or deep socket.
Sensors are on e-bay.com in the $20 range.
You should be able to effect the change,but I recommend you feel comfortable with your own skills and knowledge.Check the JTIS if not sure
Old Apr 6, 2013 | 11:03 AM
BmwR60's Avatar
Thanks a lot - I will get started on this today.
Old Apr 6, 2013 | 11:38 AM
Originally Posted by Six Rotors
............ You should be able to effect the change,but I recommend you feel comfortable with your own skills and knowledge.Check the JTIS if not sure
+1
Here's the JTIS section on ECT Sensor removal and refitting on your 4.2:
JTIS - S TYPE 4-2 Engine Coolant temperature Sensor.pdf
As you've had the engine running, give it time to cool right down before starting to remove the broken sensor..
Old Apr 6, 2013 | 04:05 PM
BmwR60's Avatar
Thanks everyone. Job completed and running fine now.
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
04Xjrsteve
May 7, 2019 04:06 PM
adam699
Oct 13, 2015 05:53 PM
