P0031 code and puzzled 2005 ST
Old Sep 6, 2014 | 08:25 AM
scotaidhcecilio's Avatar
Default P0031 code and puzzled 2005 ST
I have a 2005 ST 4.2 l and replaced the a/f sensors both in front. Denso 234-9030. Still have the MIL popping. Replaced the relay just in case. Still on. Any ideas on what I might be missing?
Old Sep 6, 2014 | 08:28 AM
JagV8's Avatar
P0031 isn't a MAF code. Grab the free codes PDF / JTIS and see what the known causes are.
Old Sep 6, 2014 | 08:39 AM
Default P0031
My OBD II says HO2s Heater Control Circuit Low Bank 1, Sensor 1. The MAF could be a possibility as I got O2 type codes when my Disco II MAF failed.
Old Sep 6, 2014 | 11:11 AM
JagV8's Avatar
If that's logic.... words fail me.
Old Sep 6, 2014 | 10:04 PM
Default P0031
When reviewing the response, I thought it was stated as it was a MAF code. I miss read the reply. And yes, MAF failures throw o2 sensor failure type codes in discovery II.
I replaced both upstream sensors and still have the code appearing. If anyone has run across this issue, please let me know how you sorted the problem.
Old May 4, 2015 | 10:28 AM
Akenoten's Avatar
Default Had the same problem
My S type has the same problem. Failure of the ECM. Replaced and all sorted. Jag shop said he had seen the problem before but had been unable to correct for other customers.
caveforce
38
Nov 16, 2015 10:19 AM
Tipptone
Sep 16, 2015 07:39 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
rachelstr
Sep 3, 2015 12:59 PM
