P0171 Fuel Trim System Lean (Bank 1) ???
Old Feb 17, 2009 | 12:48 AM
phd12volt's Avatar
Default P0171 Fuel Trim System Lean (Bank 1) ???
I seem to pop this code if i idle the car for a short time (say 20 min). Its not that big of a deal really, it doesnt show up at all if i drive it. Just shows up after idling for a bit. I can shut it off with my scanner. What usually does this or shall i ask, what would be the most common thing that contributes to this???
Old Feb 17, 2009 | 01:36 AM
whiteSTR's Avatar
I hate to speculate, but if it was my car I would start checking vacuum lines, clean the MAF, and check the EGR.. you most likely have a vacuum leak, probably a very small one.. How is the idle on the car? Does it get rougher when the code comes on while the car is idling? Eric
Old Feb 17, 2009 | 02:25 AM
phd12volt's Avatar
seems to idle fine even with the light on. runs fine too even though "restricted performance" shows up. I don't know though. maybe that's why im getting 27mpg...lol. ill start checking the vacumn hoses and work my way around I guess.weird thing is it only does it when I idle
Old Feb 17, 2009 | 02:54 AM
whiteSTR's Avatar
Lol yeah it's funny that when you have a P0171 and your car is running lean you will see a huge increase in your mpg sometimes over %35.. I would say you have a gasket or a hose that's cracked and is setting off the code.. Try the easiest thing first though: clean the MAF and reset.. Then start checking for leaks.. Eric
dsnyder586
Dec 29, 2024 07:39 PM
jdzubas
Oct 4, 2015 09:14 AM
OkieTim
Sep 8, 2015 04:48 PM
AL NZ
Sep 4, 2015 08:39 PM
OkieTim
Sep 2, 2015 12:48 PM
