P0420, P0430, P1131, P1151 (catalytic converters, and oxygen sensors)
Old Jan 13, 2016 | 08:11 AM
LoopbackZero's Avatar
Default P0420, P0430, P1131, P1151 (catalytic converters, and oxygen sensors)
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
P1131 - Oxygen Sensor Engine Lean (Bank A) Upstream Catalytic Converter
P1151 - Oxygen Sensor Engine Lean (Bank B) Upstream Catalytic Converter
My 2001 has 140k miles on it; should I replace the entire exhaust system, or just the cats? Is it worth changing all the O2 sensors at this point, or just the two upstream that are retuning faults? I had a P0133 (slow responding HO2S) last week, as well.
Old Jan 13, 2016 | 09:45 AM
JagV8's Avatar
If O2s on both sides went bad together I'd be looking for a common cause (wiring, fuse, relay, ...)
Otherwise just replace the upstreams and see what happens.
Old Jan 13, 2016 | 02:04 PM
tbird6's Avatar
Clear the codes and see what comes back. As JagV8 said it's hard to believe both side would go bad at the same time?
philwarner
Jan 18, 2016 11:42 AM
zidjan
Jan 13, 2016 12:14 PM
XKOwner
Dec 24, 2015 04:44 PM
user 36297240813
Dec 24, 2015 12:49 PM
DerekShiekhi
Dec 19, 2015 12:24 AM
