parkbrake fault
Old Apr 7, 2014 | 01:29 PM
biffo17's Avatar
Default parkbrake fault
had the parkbrake fault messege appear today , not working at all.
got it up on a local ramp , it looks like the cable has snapped, right above the rear diff a small aluminium housing completely snapped ?? i can grab both ends of it
can anyone advise on the repair or replacement of this .
will it be a full replacement or can just the cable be renewed ??
thanks
Old Apr 7, 2014 | 01:36 PM
maxthrottle's Avatar
If your 2002 STR is like my 2003 STR, you're going to need a new assembly.
The assembly has the motor and gearbox connected to a new cable. If I recall correctly, the part wasn't terribly expensive $250 or so? Installation can be tricky as it lives right on top of the rear axle pumpkin.
There are some posts about it. A former member, phd12volt, was able to do his own repair. I had a local garage take care of it for about $200.
Old Apr 7, 2014 | 01:43 PM
Originally Posted by biffo17
......... will it be a full replacement or can just the cable be renewed ??
Is the required cable either Item 3 or Item 4?
Nine difference part Numbers depending on VIN. If it is one of these you need, post back your VIN range and I'll get the P/N.
Old Apr 7, 2014 | 02:33 PM
biffo17's Avatar
looks a lot like 3 in the diagram
Old Apr 7, 2014 | 02:49 PM
Here's the complete P/N listing for Item 3:
Old Apr 7, 2014 | 04:22 PM
biffo17's Avatar
m73946 VIN NO
c2C7715 Found a supplier close to me £30.00 looks a nightmare to fit !!
what could cause this to break ? age, wear
Thanks for all your help
Old Apr 17, 2014 | 02:48 PM
biffo17's Avatar
all sorted
luckily it was just the cables
JaguarLover101
48
Jun 12, 2023 10:28 AM
magmedia
Aug 15, 2019 08:54 PM
dmatthewman
Sep 30, 2015 10:10 AM
zoozth
Sep 29, 2015 07:28 AM
