Passenger Side Mirror
Old May 13, 2008 | 05:19 PM
FactoryJaguarTech's Avatar
Default RE: Passenger Side Mirror
Does the driver mirror go down?
If so it is likely the mirror motor.
Old May 13, 2008 | 06:01 PM
You pull the glass out of the mirror housing. Push it left into the housing, then pull on the right side. It will eventually pop off. Then you will see the mirror motor. 3 torx bolts holding it in. Replace it and put glass back in. Start with right side, then clip in the left. Job done.
This is not definitive that motor is your problem....but likely based on your description.
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
doctordeuce
Sep 12, 2015 08:30 AM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
