Plastic Part?
Old Nov 22, 2015 | 03:37 PM
Dennis Catone's Avatar
Default Plastic Part?
Is the thermostat housing cover one of those plastic parts that can crack and leak? I am not sure if I have a leak from the hose or the hose connector. (if plastic)
I hate wasting money but in this case it might be worth buying both if the part is plastic.
Old Nov 22, 2015 | 05:50 PM
davidladewig's Avatar
I bought a metal one just to have it in case. Unbelievable the amount of junk plastic in these cars.
Old Nov 22, 2015 | 10:10 PM
Warspite's Avatar
True that! Plastic timing chain tensioners for a start. Junk for sure.
Many of these original high failure parts have been replaced by metal ones; as even Jaguar acknowledged that plastic was a poor choice to begin with.
Last edited by Warspite; Nov 22, 2015 at 10:19 PM. Reason: Spell Check is your Friend.
Old Nov 23, 2015 | 07:40 AM
Jon89's Avatar
The plastic thermostat housing is indeed susceptible to warping, cracking, and leaking. The leak in my wife's XK8 exactly one year ago resulted from a warped thermostat housing. I nailed it down with a pressure test kit loaned from Advance Auto Parts. After doing the research on the XK8 forum and getting good advice from other 4.2 engine owners, I opted to replace the entire black plastic cooling outlet duct assembly and be done with it. No issues since....
Old Nov 24, 2015 | 03:27 PM
Thanks Jon89 for the info on doing a pressure test. Is the thermostat outlet removed from the car and then tested?
Old Nov 24, 2015 | 04:52 PM
Jon89's Avatar
No. You utilize the appropriate cone-shaped adapter from the pressure test kit that fits snugly down into the coolant reservoir (after removing the reservoir cap) and pump it up using the kit's hand pump. Your leak will become obvious (and usually enlarges) pretty quickly, so park the car where you plan to effect the necessary repairs before you perform the pressure test. Once you've done the pressure test, it's a good idea NOT to crank the engine again until you have completed the repairs....
Audiguy
Jan 7, 2016 06:16 PM
95 AJ16-5
Nov 20, 2015 11:34 AM
Malihide
Nov 17, 2015 12:55 AM
kmarajh
Nov 16, 2015 09:29 AM
jimateo
Nov 15, 2015 08:13 PM
