Please help: no hot air or pressure from bleeder
Old Jan 13, 2014 | 12:19 AM
lindstromjd's Avatar
Default Please help: no hot air or pressure from bleeder
2000 4.0 S-type. Did some engine work with the engine outside the car, and now I don't know why I have no hot air. Sometimes it can get about lukewarm, but then it goes away. I've tried bleeding the system the way JTIS says, and I get no pressure from the bleeder. Maybe a very slight drip for 2-3 seconds, and then nothing.
The 3 lines all going to the heater core all get hot. The aux water pump is working. The blend door inside the cabin is working. The A/C works and blows cold air. When I choose full hot on the climate control, I don't get any heat.
What else can I look at? Anything I'm doing wrong?
Old Jan 13, 2014 | 08:12 AM
police666's Avatar
sounds like an airlock to me, are you letting it get to temp ? also try it on an angle as ive read this can help
Old Jan 13, 2014 | 11:20 AM
Car gets up to temp pretty quickly; and doesn't overheat. I did try the angle trick, to no avail. I'm about to drain the whole system and start over.
Old Jan 13, 2014 | 12:02 PM
Have you tried flushing the heater core?
Old Jan 13, 2014 | 12:07 PM
What's the procedure for that?
02jagstype
23
Oct 23, 2022 07:03 PM
explorer364
Sep 11, 2015 05:44 PM
OkieTim
Sep 8, 2015 04:48 PM
Corycarlo
Sep 5, 2015 11:41 AM
OkieTim
Sep 2, 2015 12:48 PM
