PO104 OBDII Reading
Old Feb 13, 2015 | 10:01 AM
baylward's Avatar
Default PO104 OBDII Reading
I have a check engine light that came on. I have a 2006 S-Type 4.0 with 58,000 miles. The OBDII Readout showed a PO104 reading. I have been told that this may be a MAF Sensor. Is that correct? Where do I start and where is the MAF Sensor located. Are they hard to replace? Are they expensive???
Old Feb 13, 2015 | 10:06 AM
Welcome to the forum baylward,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Feb 13, 2015 | 11:13 AM
NBCat's Avatar
If the MIL comes on and the code stored is P0104, you can begin by checking the wiring to the MAF (mass air flow) sensor, which is located between the air cleaner and the inlet manifold on the engine. If the wiring is not an issue, you can inspect for an air leak causing the engine to run lean. Fuel trims will also show this to be the case if there is an air leak.
A 2006 S-Type has the 4.2 litre engine. If you do not already have it, you can download the JTIS to your computer from this forum. Look in the 'stickies' for a listing.
Old Feb 14, 2015 | 11:52 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
..I have been told that this may be a MAF Sensor..Are they expensive???
Lots of great info already posted on this Forum by extremely knowledgeable S-Typers on virtually any topic related to your car. Learn to use the Search and Advanced Search features.
For prices search Forum sponsors SNG Barratt and JagBits; also eBay, Amazon, Autozone, RockAuto.com and your local Jag dealer for comparison.
Bcrary3
Sep 12, 2021 05:41 AM
philwarner
25
Jun 26, 2021 05:43 AM
scooternva
19
Oct 27, 2015 02:14 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
explorer364
Sep 14, 2015 07:43 PM
