possible timing issue
Old Apr 22, 2015 | 07:22 AM
  #41
NBCat's Avatar
Based on the sound in this most recent video, there may be a bent valve.
Old Apr 22, 2015 | 08:02 PM
  #42
seagates5's Avatar
Ugh..I was afraid of that. I was going to check the valve lash to see if they were out of spec
Old Apr 24, 2015 | 03:18 AM
  #43
seagates5's Avatar
I checked all the valve lashes and they all were consistent and within spec on all except the driver side intake valves
Old Apr 26, 2015 | 07:57 AM
  #44
NBCat's Avatar
If you do indeed have a bent valve on the LH (Bank2) cylinder head, the engine must be removed from the car as the head on that side cannot be taken off with the engine in situ.
Old Apr 27, 2015 | 01:15 AM
  #45
seagates5's Avatar
Ugh...They should have put that in the JTIS, thats good to know
Old May 2, 2015 | 04:28 PM
  #46
seagates5's Avatar
I had a dry and wet compression done and it indicated that the piston rings are worn. The dry compression was 90psi and after the squirt of oil it went to 130psi on the first cylinder of the LH bank
SD96XJ6L
Jan 12, 2022 04:30 AM
Rupesh
Mar 25, 2016 03:33 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
Jandreu
Aug 29, 2015 07:31 PM
