Power steering fluid leak nearside below resevoir
Old 08-08-2017, 04:27 PM
Gerry McLaughlin's Avatar
Default Power steering fluid leak nearside below resevoir
My 2001 s type 3.0 V6 has developed a leak which appears on the ground , nearside just around the front wheel. Any ideas ?
Old 08-09-2017, 10:08 PM
Received 1,423 Likes on 1,066 Posts
Worn PS hose, worn PS pump or seal at the PS pump.
Old 08-09-2017, 10:31 PM
Jaguarstyper's Avatar
The first few years of the s type were terrible reliability wide and that is one of the problems.try the dealership or check the hose and if you find the leak in that ducktape it until a replacement can arive
Old 08-12-2017, 01:12 PM
clubairth1's Avatar
Received 2,289 Likes on 1,798 Posts
Had a leak in my Lincoln LS in the same area and the P/S pressure sender was leaking. Much cheaper than a hose.
So get it up in the air and take a look. You won't know until you do.
