question about jump starting
Old Jun 19, 2008 | 12:40 PM
harounq21's Avatar
Default question about jump starting
Hey guys. I am new to this forum and have recently bought a 2001 4.0 s-type. I was wondering how would Ijump start the car if I ever needed to. I know you cannotuse the negative ground on the battery. It seemsI am also missing the ground metalrod that holds the spare tire in place. Any suggestions where to ground it??????
Old Jun 19, 2008 | 12:57 PM
whitestype's Avatar
Default RE: question about jump starting
i am also new to this site and was wondering what the reason is why you cant use the neagtive terminal will that do something to the car?
Old Jun 19, 2008 | 02:47 PM
harounq21's Avatar
whitestype, the reason why you cannot use the negative terminal is quite clear. First of all, where is your battery? In the trunk. Next, where is your fuel door/tank? Right below the battery. Using the negative terminal will cause a spark and ignite your gas tank on fire.
Old Jun 19, 2008 | 04:35 PM
cosworth's Avatar
Put the terminals on the S-type first. No spark created.
Old Jun 19, 2008 | 06:12 PM
surreptitious's Avatar
ORIGINAL: harounq21
wow, that's a good point. i was thinking the same thing whitestype was...should work if you put the jumper cables on the battery terminals in the trunk first...now what happens if you're jumping another jag? flag someone else down!
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
Charlene n John
Sep 28, 2015 06:01 AM
tberg
Sep 7, 2015 07:32 AM
