Quick Rear Suspension Question
Old Sep 19, 2021 | 07:11 PM
jazzwineman's Avatar
Default Quick Rear Suspension Question
I noticed I need to replace on the rear of my 05 Std suspension the left and right sway bar links and the tie rod ends on both sides. Alldata has made changes and not for the good and no longer gives me instructions fro some items.
Both of these parts looks very straight forward. Is there anything special about the replacement of either or anything I need to protect from or an trick that seems to escape my eye? Do I need to support or raise and lower anything as I do on the fronts for the stabilizer links?
I am getting Moog and Lemfoerder parts.
Thanks for the quick help
Tom in Dallas/Plano
05 S-type 3.0 121k
Old Sep 19, 2021 | 10:34 PM
scottjh9's Avatar
The rear is pretty simple. Just make sure you put the park brake cable on the correct side of the link. Usually there is a rub mark on the cable from where it was. Tie rods are simple measure before and after. I did mine on ramps so nothing could move and then fit them. Had the alignment checked and it was right on
Old Sep 19, 2021 | 11:47 PM
TBB
jacklynthejag
Jun 18, 2018 08:42 PM
imageoftheson
Oct 13, 2017 11:00 AM
NDW
Dec 29, 2015 07:34 AM
Jon89
Aug 8, 2015 05:08 AM
EZrider800
May 24, 2012 08:16 PM
