Rear Brake Pads
Old Aug 25, 2022 | 02:14 PM
Plumbo's Avatar
Default Rear Brake Pads
Hi All, I have just replaced the rear brake pads on my 2004 S type 3 Ltr V6 Petrol Auto. The pads were listed on the MOT as worn. My reason for posting is to say that I used a cheapo £14 HILKA Caliper Rewind tool to do the job. Both calipers wound in using the Right-hand thread tool. I drained some fluid from the master cylinder tank before winding back the pistons (used a garage syringe) and topped up the fluid when done. This was my first job on electronic hand-brake wind-in calipers as I am more used to working on older cars. This was a DIY in the driveway job and took about 4 hours total. What ho- Plumbo
Old Aug 26, 2022 | 05:07 PM
Aarcuda's Avatar
Good job
Old Aug 26, 2022 | 06:44 PM
Sportston's Avatar
Well done, think I might have to do similar to mine. I keep hearing a clunk from the rear when I pull away after firm braking. Think my pads may be sticking, or calliper. I have one of those winding tools too; a very useful piece of kit!
Old Aug 27, 2022 | 02:39 AM
neilr's Avatar
Possible that the anti-rattle inserts are missing and you have the shorter pads that need them. The longer pads fit straight into the carriers but they do wear the carrier surface over time or at least my Redstuff did. Another good reason for dropping them in the round filing cabinet
Old Aug 27, 2022 | 07:26 AM
Sportston's Avatar
Thanks. That’s a good possible cause, but my thunk doesn’t sound like that. It sounds like when your handbrake has stuck on and suddenly releases when you drive forward. However, I will check what you suggest anyway while I am there.
Old Aug 27, 2022 | 11:50 AM
neilr's Avatar
Other things to check are the diff mounts and the driveshaft donut joint. There is a diff mount kit for the earlier car, so it is a known possible problem.
Old Aug 27, 2022 | 12:22 PM
Sportston's Avatar
The donut is ok but I wonder if you might have put your finger on it with the diff mount. It sounds and feels like a muffled thunk, not metal on metal. I will defo look at the diff mounts.
Pompey
Sep 1, 2019 09:27 AM
85xj6iii
Sep 25, 2014 02:32 AM
cliff328
21
Nov 7, 2011 04:38 PM
Iluvmy05STR
Nov 17, 2009 12:16 PM
Humy
May 14, 2007 05:31 PM
