Rear control arm bushings
Old Sep 11, 2010 | 08:27 PM
bobby181's Avatar
Default Rear control arm bushings
Hey whatz up every one. I just found out that my need some suspension work. I know that for the most part and I ordered up some new sway bar bushing and links front and rear. I was planning on doing also new shocks an H&R springs but, that looks like it going to have wait. I found out that my lower rear control arm bushings are shot and need to be changed out and rear stabilizing links. I found out that the bushing on the lower control arm can be change out instead of buy a whole new control arm for $800 buck a pop. I found this out on
http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=34593
They are from racing green cars ltd. They have made some replacement bushing that you can press in.
http://www.thejaguarshop.com/Jaguar/...wards/b%7C.htm
I am going to be ordering up some soon. I was wondering if anyone has done this before?
Old Feb 5, 2011 | 12:32 PM
mikewv100's Avatar
Default results of bushings for lower control arm
I have the same issue with control arm bushings and was wondering if you tried the ones from racing green ltd? How did it work?
Old Feb 5, 2011 | 12:36 PM
bfsgross's Avatar
Also try JagBits, Nalleys Jaguar, etc.
Old Feb 6, 2011 | 12:17 PM
cacloss's Avatar
I tired Nalley and was told you have to buy the whole component with the bushing in it... you can't buy just the bushings.
I would also be very interested to know if the ones in the OP worked. Thanks
Old Feb 6, 2011 | 01:14 PM
bfsgross's Avatar
There's a bushing available that can be pushed in. I'll check threads for you but search around the threads for the part number mentioned in threads a while back.
Old Feb 8, 2011 | 04:29 AM
jaglover922's Avatar
Default Bushings
Just leave the bushings alone. Does the suspension have any kind of noise in the front or rear, any kind of play??? If not then I would leave them alone altogether. The control arm bushings being crack never cause any issues that I have seen, The front links and sway bar bushings on the front can make clunking noises, but the rears I have never seen those make noise. Unless you have excessive play or a noise, I would leave them alone.
RaceDiagnostics
Sep 7, 2015 07:28 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
