rear level sensor connection
Old Jun 13, 2017 | 09:54 AM
the groove's Avatar
Default rear level sensor connection
I have a 2005 S type R and the rear level sensor that clips to the upper control arm is loose there was a big enough gap to put a 3/4 piece of hose in there to stop it from moving around any idea what really belongs in the space? should have a pic of the clip/ sensor I found.
Thanks, Rich
Attached Thumbnails rear level sensor connection-s-l1600-s-type-r-sensor.jpg
Old Jun 13, 2017 | 05:46 PM
daro31's Avatar
Default Picture of sensor bracket.
I took a number of photos of the rear end of my 2008 S-type before I removed it for a refurbishment. I don't know why there is all that clearance but you can see hear how it fastens.
Old Jun 14, 2017 | 07:40 AM
the groove's Avatar
Thanks for the photo my clip was loose and could be moved buy hand and my rear suspension had a squeak that I hope I have fixed with the piece of rubber hose that I put in the gap to hold it in place better?
Old Jun 14, 2017 | 08:20 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
I don't know about the STR but for my S-Types a squeaking rear means 1 or more rear suspension bushings are failing. Quite a few threads on this forum; please do a search. Also, YouTube has at least 1 video on bushing squeaks.
Old Jun 14, 2017 | 08:28 AM
the groove's Avatar
Well my initial question was if there was something missing (i.e a rubber insert) in the large gap that is on the clip to the upper control arm.
Old Jun 15, 2017 | 01:15 PM
But you also posted this, didn't you?
...my rear suspension had a squeak that I hope I have fixed with the piece of rubber hose that I put in the gap to hold it in place...
Just trying to help out. I won't waste my time in the future. Do your own homework. Good luck.
Old Jun 15, 2017 | 01:51 PM
the groove's Avatar
Its all good my fix seams to have worked to tighten up that bracket just wondered if something was designed to fit in the space. Thanks for your help
