the rear sway bar mounts
Old Jul 20, 2024 | 03:41 PM
Markje1978's Avatar
Default the rear sway bar mounts
So guys the rear sway bar mounts are a disaster to replace there is hardly room but it's manageable....so my question is are the original ones made in 2 halves?
I have the febi ones but they are a really a pain in the **** to get them in the sway bar nearly impossible....or did you guys mounted the power flex/ steongflex ones?
Old Jul 21, 2024 | 10:37 AM
Sportston's Avatar
I used Powerflex bushes. There are NOT two parts per bush. I dropped the subframe when I did mine. Use rubber grease to aid assembly. Make sure you have the correct size bushes (IIRC there is a different size option, depending on which model you have). Don’t lose the retaining brackets, like I did🙄.
XK8 Comfort
Jul 21, 2021 06:01 AM
al_roethlisberger
May 25, 2017 07:05 PM
weisberg
Jul 20, 2014 11:34 AM
ez53436
Jul 10, 2013 10:19 PM
Ahiman
Jun 3, 2013 04:31 PM
