remote start help,,
Old Feb 5, 2011 | 12:37 PM
Jag Breeder's Avatar
Default remote start help,,
I'm almost finish installing my remote start but I have a tach wire from the alarm system that says it need to be wired to my ignition + wire can anyone help me with this what wire on a 2001 s type at the ignition coil do I need to splice into
Old Feb 5, 2011 | 08:28 PM
androulakis's Avatar
It's not at the ignition coil. You need to tap off of any of the fuel injectors harnesses. Each one will have a brown and something strip wire for positive, Dark green and something wire for negative.
The dark green is the one you want. Basically this tells the alarm that the car is running.
Take care,
George
Old Feb 5, 2011 | 08:43 PM
thanks im gone try it ill let you know if i finish it
Old Feb 5, 2011 | 08:44 PM
oh question do i need to remove the manifold to get to it?
Old Feb 5, 2011 | 08:56 PM
No you can tap any of the green wires on the fuel injector harness. You can even go to the PCM. I can post a diagram with pin info @ the pcm if that makes it easier.
Once you take the plastic cover off the drivers side of the engine they should be easily accessible. All you need is one of the wires. Remember all of the injectors pulse each time the engine completes a revolution.
Do NOT cut this wire or use one of those cheezy scotch lock tap things. Take a razor blade and strip the insulation about 1/4" all around the wire.
Then take the blade and separate some of the strands so the wire looks like this:
===-O-=== Where the equal sign is the insulated wire.
Then stick your new wire through the "hole" you created. Twist and solder. Then insulate with preferably fabric electric tape, but regular tape will do.
Take care,
George
Old Feb 5, 2011 | 08:59 PM
yea can you send post the diagram please and thanks
Old Feb 5, 2011 | 09:11 PM
Sorry I didn't realize the ground side didn't actually connect to the PCM.
You're going to have to tap one somewhere in the fuel injector harness.
I highlighted the wires in red.
Take care,
George
File Type: pdf
Old Feb 5, 2011 | 09:19 PM
i can use any one thats highlighted correct?
Old Feb 5, 2011 | 09:21 PM
Yes Sir.
Old Feb 5, 2011 | 10:07 PM
is that plastic piece you talking bout got jaguar v6 wrote on it
Old Feb 5, 2011 | 10:24 PM
Yes Sir
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
mbergen
Oct 23, 2019 10:26 PM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
