Rot/Rust/HOLE on rear subrame 3.0 S type
Old Jul 13, 2014 | 05:36 PM
bonnietiler's Avatar
Default Rot/Rust/HOLE on rear subrame 3.0 S type
I was giving the car a good clean up behind the off side (rt side if stood behind car) rear wheel got all the crud off and WHOO....hello hello..a hole 1" across on the bottom + rot etc on the tubular section of the rear subframe which holds the top wishbone..it did not look good..Is this normal is the car dead..can it be welded.awfully near to a lot of brake pipes etc.
Any help much appreciated
Brian
Old Jul 13, 2014 | 06:48 PM
Tijoe's Avatar
Is the hole in the Sub-frame or in the body? The sub-frame can be replaced. The body would have to have the rusted panels cut out and repaired.
Old Jul 14, 2014 | 01:11 AM
Definitely the subframe..it's the structure that goes from one side of the car to the other holds the rear suspension in place.
Brian
Old Jul 14, 2014 | 10:38 AM
Tijoe's Avatar
Brian
Start looking on E-bay for a sub-frame that fits your model year car. Should be several available in the $150 price range. I've purchased a couple for $100 for my projects.
It is a straight forward job to swap it out, but will take some time. If you can do it without taking apart the brake lines, it will save a lot of time. While you are at it, you should inspect all the control arm bushings and replace as needed. You will have to plan on getting things aligned after you swap the parts. If the car is rusted out I would suspect that many of the other parts have been exposed to the same conditions that caused it to rust in the first place.
Pictures would be nice of the damaged areas....
stanjag
Dec 29, 2024 08:26 PM
johanasu
Sep 3, 2015 12:39 PM
wwac
Sep 1, 2015 05:45 AM
hawianjim
Aug 29, 2015 07:23 PM
mkrion
Aug 26, 2015 11:43 AM
