Rotors/Pads
Old Nov 29, 2011 | 06:09 PM
pastype's Avatar
Default Rotors/Pads
I'd like to give a slight upgrade to my front brakes and was wondering if you guys lean toward a particular combo. I've had factory Brembos on my Cobra in the past, but the OEM replacement slugs they sell for daily drivers are not quite up to the degree of their price tag. I'm leaning toward EBC rotors and EBC red stuff pads (gotta go British, right?). I've used this combo on my TL and have been very happy (no hub rust). I've also used ATE's in the past with great results. Your thoughts?
Old Nov 30, 2011 | 06:35 AM
The Chris X's Avatar
Big fan of the Akebono ceramics on my STR. Almost no dust, very good stopping power, no noise. Can't recommend a rotor for your car as we don't have the same setup. I've used EBC rotors many times and have no complaints though.
Old Nov 30, 2011 | 09:35 AM
Bacardi 151's Avatar
Multiple tests have shown that blank rotors outperform drilled/slotted/dimpled from a cold stop (most likely on a street setup)...When racing while the rotors usually remain hot, some setups may benefit from drilled/slotted/dimpled...So if you're looking for more bite on a street setup and are spending the big bucks on drilled/slotted/dimpled understand you could be wasting your money...I needed new rotors and went with a drilled/slotted setup for the soul reason of bling (and the fact they weren't too much more than OEM)
Old Nov 30, 2011 | 09:48 AM
Mikey's Avatar
Originally Posted by Bacardi 151
Multiple tests have shown that blank rotors outperform drilled/slotted/dimpled from a cold stop (most likely on a street setup)...When racing while the rotors usually remain hot, some setups may benefit from drilled/slotted/dimpled...So if you're looking for more bite on a street setup and are spending the big bucks on drilled/slotted/dimpled understand you could be waiting your money...I needed new rotors and went with a drilled/slotted setup for the soul reason of bling (and the fact they weren't too much more than OEM)
which I think means 'I agree'.
Slotted and drilled are pure bling- nothing to do with improved stopping power on the street. What works on some cars on the race track doesn't inherently apply to street cars in traffic.
I put Raybestos brand rotors and ceramic pads on my non-R and couldn't be happier.
pab
Jul 28, 2015 08:28 AM
rasputin
Jul 21, 2015 11:02 PM
Jimscriv
May 19, 2014 06:15 PM
