RPM goes up and down
Old Aug 9, 2017 | 08:02 PM
jaguar_man's Avatar
Default RPM goes up and down
Hi All
I bought 03 S type 3.0 ...3 days ago. The car is clean..however i have a couple of questions but for now my major concern is that the RPM goes up and down by itself between 40-55 speed ( sometimes starts from 30)..then onces i go over 55, the car gets stable.
Please help me ..thank you
Old Aug 10, 2017 | 02:59 AM
joesoap's Avatar
This is known problem called the "Lurch" and is a peculiarity of the 6 speed auto box introduced in 2003 do bit of research, it happens during warm up on light throttle or gradients.
Owners claim to have cured by adding Lubegard shudder fix or Platinum additive.
It doesn't appear to be terminal and at worst can be cured by a new Torque converter:
I would add the Lubegard Dr Tranny shudder fix first.
Old Aug 10, 2017 | 04:31 AM
JagV8's Avatar
I don't think it's any lurch.
Instead, it sounds like the hunting problem (aka surging) often posted about (read the threads) and described in a TSB (free to download). Probably S307-14
Old Aug 10, 2017 | 06:34 AM
Mikey's Avatar
Originally Posted by jaguar_man
Hi All
If this goes away when the car warms up fully, then it is probably the software version as described by Jag V8.
Old Aug 11, 2017 | 10:24 AM
joesoap's Avatar
Yes I stand corrected I said "Lurch" and brain was describing the other issue, an ageing brain is a hellish thing at times,
software update doesn't always cure it I used Lubegard.
The lurch if I remember was the Thunk as you come to a stop?
Old Aug 12, 2017 | 12:36 PM
jaguar_man's Avatar
Thats all for helping answers. In fact it doesn't go away after warming up. However when it is happening, there is a sound coming up like am driving on the side-way alert bumps on high way [those little continues sequential bumps] !
Old Aug 13, 2017 | 03:17 AM
joesoap's Avatar
Well in that case you need to get it plugged into a diagnostics machine, it could be drivetrain and not transmission or both but without codes it wont be easy.
Old Aug 13, 2017 | 07:41 AM
Mikey's Avatar
Does the surging go away if you keep it manually in 4th gear at highway speed?
Old Aug 16, 2017 | 08:57 PM
jaguar_man's Avatar
In fact, once I am over 50 it goes away completely
Old Aug 16, 2017 | 09:52 PM
Mikey's Avatar
I'd start with a fluid change then.
Old Aug 18, 2017 | 08:36 PM
aholbro1's Avatar
I recall a recent thread describing a similar symptom...turned out to be a bad ignition coil. Search tool should reveal it soon enough.
