s button for transmission
Subscribe
Mar 7, 2011 | 07:02 AM
I wish we did have some selectability of the CATS. But both functions could have easily been engaged via single switch for the cars that do have CATS. But a four position soft-reg-sport-track selection switch sould be my choice. Oh well ... a 2011 XFR I guess.
Quote: no, how would it do that without Cats suspension? of which most do not have.
Reply 0
Feb 18, 2020 | 11:58 AM
Quote: it does not eliminate any gears...that makes no sense otherwise, if it did, , at highway speeds you would be in 5th pushing 2500 rpm in 5th.
Simply put, it holds more rpm between shifts then in non sport, and under more spirited acceleration it downshifts sooner, As we know, the str is inexplicably geared all crazy as if it were not a super sedan that should rev, so in non sport, under normal acceleration the trans shifts almost immediately out of first and into second as a fuel saving procedure...I hate it..so I never drve without sport mode on.
Thankyou for clarifying that point as a few so called experts on other sites have insisted that 6th is not assessable in sport, mine is in sport most of the time as I think it drives more true that way, fuel consumption is actually a little better too
Reply 0
Feb 18, 2020 | 12:17 PM
My S-type 3.0, obviously not an STR, will delay shifting into 6th until roughly 80 MPH when "S" mode is engaged on the transmission (which for me is all the time...).
Reply 0
Feb 19, 2020 | 04:38 PM
Reply 2
Feb 21, 2020 | 05:06 AM
As I understood it, you still get 6th gear but the torque converter doesn't lock. It keeps the coupling fluid. Shift points are obviously altered to make the upper rpm range available. We all know what a beautiful place that rpm range is.
Reply 0
Feb 21, 2020 | 09:57 AM
I reckon it will lock. Did you read a Jaguar document that says otherwise?
Reply 0
Feb 21, 2020 | 10:57 AM
Very vague recollection on my part. I had been getting deep into research of the ZF material prior to doing my fluid and filter service, but that was some time ago. I recalled some mention of the S switch holding out lockup for the top gear along with the shift point profile change. Almost to sound that if you had fifth engaged on the shifter, it would become the top gear only allowing for lockup in the lesser gears, but that possibility was only wondered by me, not read. The ZF was pioneering in its day particularly in how it modulated it's lockup in all gears. Was it Jaguar documentation? Maybe not, it may have been ZF. Perhaps it does lock but just differently as does the shifts. In the end, it doesn't matter to me, I just love the transmission. So smooth. I can honestly say that I love literally everything about this car. My favorite by far, and I've had a lot of cool rides.
Reply 0
Feb 21, 2020 | 12:42 PM
  #28
The jag doc make a point of saying it locks in all forward gears. Makes sense that it would, whether in S or not.
Reply 0
Feb 21, 2020 | 03:01 PM
In 3.4 and 3.4.1 lines can be drawn that among other inputs, the mode switch contributes to alteration of shifts and lock up to match current style while reserving the ability to return normal lockup when enthusiasm return to normal. It also says somewhere in there that the lockup pressure is always in play just modulating to some variable output. Either way, it shows a sophistication in operation that goes beyond more simple decision trees within the controller. Certainly can appreciate what it does for me.
Reply 0
Feb 21, 2020 | 05:21 PM
  #30
I don't get why it would want to not be locked. To change speed the car can just change revs. What sense can it make to not be locked up?
Bear in mind the PCM & TCM exchange messages via CAN all the time.
Reply 0
Feb 21, 2020 | 06:27 PM
  #31
I can see how it makes sense. The torque converter locks as to save MPG through lowering revs and removing slip, it also lowers heat which in the simplest sense, heat = wasted energy not put to work. When unlocked, the torque converter brings benefit as a torque multiplier. It is why it has to wait until it has a cruising type load as to allow lockup in the first place. Once again, it is the control intelligence being applied to modulate the lockup to in effect, ride a curve more precise than most other cars and involving more forms of input. Particularly impressive considering the era being discussed. It isn't horsepower making sport mode so satisfying, it is the throttle responsiveness that I have appreciation for.
Reply 1
Feb 22, 2020 | 01:40 AM
  #32
I'd say it can get responsiveness from engine revs without messing with the lock up.
If anyone wants to monitor the CAN packets it's a way to be sure...
Reply 0
Subscribe
Currently Active Users (1)
