S-type 2.5 SE 2002 petrol smell
Old Feb 17, 2019 | 03:57 PM
Magdy Tawfik's Avatar
Default S-type 2.5 SE 2002 petrol smell
Hi Guys
When start my car about 6 months now I smell gas from the exhaust.
What can cause this smell?
Mag
Old Feb 17, 2019 | 08:48 PM
scottjh9's Avatar
Originally Posted by Magdy Tawfik
Hi Guys
Mag
Well this is a tough one with limited info....is it a raw gas smell or fumes or burnt fuel exhaust...and is it inside or outside the car the strongest
Old Feb 17, 2019 | 08:55 PM
It´s a raw gas smell when starting the engine not sure when the car is running. Where I should start with...
Old Feb 17, 2019 | 10:39 PM
scottjh9's Avatar
Look for a physical fuel leak first....have someone start the car and you look under the hood...its probably raw gas fumes, but do this first...if you have no liquid leaks then the evap....fume system....is next....has the fuel filter been changed in the last 6 months
Old Feb 20, 2019 | 04:11 PM
Hi guys
It's fuel smell comes from exhaust fuel not burned
You have any idea?
Mag
Old Feb 20, 2019 | 04:55 PM
scottjh9's Avatar
Hi guys
You have any idea?
Mag
Do you have a scan tool to read fuel trims....if yes post them ....if not get one...they are easy to use..or go to a shop and have them do a diagnostic scan....either way, we need to know this data...do you have any check engine lights on, and does the car run good besides the smell...if it is overfueling, damage to the cat converters will happen and needs to be addressed immediately...where are you located by the way
Ignas Miknevicius
Jul 25, 2017 05:48 AM
Lubino Do Rego
Jan 30, 2016 03:04 AM
Rodney Gold
Jan 22, 2016 06:31 AM
abartl22
Jan 4, 2016 06:15 PM
the almiesta
XJ40 ( XJ81 )
Mar 18, 2008 01:58 PM
