S-Type 3.0 V6 revs do not fall down
Old Sep 11, 2018 | 06:10 AM
marek7695's Avatar
Default S-Type 3.0 V6 revs do not fall down
Greetings I want to ask or someone has already solved a similar problem.
When shifting when the clutch is pressed the RPM will not fall but it will remain on 2-3000 until I stop. When I stop, they fall as they do.
The car does not show any fault codes
Old Sep 11, 2018 | 04:23 PM
NBCat's Avatar
Check STFTs and LTFTs to determine if there is a vacuum leak allowing unmetered air to enter the engine.
Old Sep 12, 2018 | 06:18 AM
wydopnthrtl's Avatar
I agree. Vacuum leak somewhere.
Old Sep 12, 2018 | 04:51 PM
marek7695's Avatar
I have checked all the seals and tubes any time but I have not found any leakage
Old Sep 12, 2018 | 06:48 PM
NBCat's Avatar
See post 2 above.
Old Sep 12, 2018 | 08:08 PM
I've had multiple cars give me fits w/vacuum leaks. Move, shake, squeeze, and no appreciable change. But disassemble, clean, and put on new hoses and BAM its working properly again. Often times its not just one fitting or hose. It's the sum of multiple leaks due to age of rubber parts.
A good strategy is to start at the MAF sensor and work your way down the air flow path all the way to the the intake-to-head gasket.
As mentioned above watching fuel trims live will give a good clue if vacuum leaks are happening.
Old Sep 13, 2018 | 03:06 PM
Jaggster's Avatar
Default High revs, too much air
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/s-type-vacuum-leak-67710/
I had that rubber connector horizontally partially split. Any leak in that breather line will also cause revs to change when iddling and engine stalling.
Tip: if you cant locate the vacuum leak by sound, as I did, spray some starting pilot fluid on the intake hoses. Go over every hose meticulously. When the engine sound changes, you have found your leak. Fluid will temporarily seal the leak, untill intake has sucked it all in.
Old Sep 14, 2018 | 07:39 AM
marek7695's Avatar
Today I checked the LTFT and STFT values and they are in the norm, they do not exceed 10% when the car is standing or while driving.
I tried to change the TPS but also no change.
I do not know the correct TPS values. When the car is standing TPS is 14.8%, but when I'm driving and shift to neutral TPS will stay at 17.1% until I stop.
Old Sep 18, 2018 | 12:31 PM
With a OBD2 scanner TPS values read something higher then 0 and never get to 100. Some readers have an option that might display it to you as 0 and 100. But the actual reading is never fully 0 or 100. You can also see V range as it moves.
Maybe a speed sensor?
Old Sep 18, 2018 | 02:01 PM
JagV8's Avatar
Trims at idle should be small, not big like 10.
The TPS is high-precision so do not mess with it!!
Old Sep 18, 2018 | 02:09 PM
Talking
Cleaning the contacts and making the ECU re-learn is a good thing in my experience. Been doing that since the 90s (don't remove it or loosen the fasteners)
Old Sep 18, 2018 | 02:13 PM
In my FORD data logging.. a good idle when fully warm will show 0-3%. Hovering in the 0.5-1.5% area is common. 8+% seems too big with a fully warmed engine.
Gibbo205
Sep 11, 2018 09:41 AM
alexcarter
Jun 25, 2014 01:48 PM
HeWhoDaresRoy
Oct 24, 2013 01:32 PM
Vee
Mar 1, 2013 06:34 PM
His_Nibbs
Sep 3, 2011 12:22 PM
