S-type banging behind glove box
Old Jul 26, 2016 | 05:21 AM
growthit's Avatar
Default S-type banging behind glove box
Hello,
I have a banging behing glove box when and only when I shut the doors with windows up. Also I get hot air from left vents and cold air from right. i know that on models with sat nav RCCM is located behind glove box. Could this be banging..? Is it a possibility the connector been disconnected hence clima not working properly?
Old Jul 27, 2016 | 03:34 AM
Datsports's Avatar
if your getting hot and cold left to right that would indicate a dccv issue . and possibly the rccm has a burnt track but that does not always happen .
it sounds more like the heaters recalculate/fresh air door in the heater intake is flapping to release the cabin pressure caused buy closing the doors , normally it would not and the cabin pressure should escape from a flap in the left rear guard behind the bumper so probably two separate issues there ! id start by checking the cabin pressure release vent in the boot/trunk is not sealed for some reason , and check the servo is connected to the fresh/recirculate door . then start on your dccv issue.
vladalexu
Apr 14, 2016 01:33 AM
gotti15
Sep 28, 2015 02:16 PM
jamesheath
Jun 28, 2007 01:05 PM
rivs
Jun 28, 2007 06:06 AM
Apr 8, 2007 02:51 PM
