S Type Bluetooth installation
Old Aug 18, 2017 | 02:58 PM
dido2200's Avatar
Default S Type Bluetooth installation
Hi everyone,
I am new on this site. My S Type 2005 has no phone install but has satnav and voice activation and mic. I am thinking of buying Bluetooth module from eBay, I need advise on the PN and where will the wiring harness be located.
Old Aug 18, 2017 | 07:03 PM
stevep10's Avatar
Have you checked to see if you already have the module installed?
If you already have the mic and voice activation then you probably already have the module.
I think it should be in the luggage compartment on the right hand side behind the carpet.
But then again I could be wrong
Old Aug 19, 2017 | 03:11 PM
melhookv12's Avatar
I thought the Bluetooth module went below the centre arm rest ???
Old Aug 24, 2017 | 11:16 AM
Joedotcom's Avatar
HI
Earlier cars needed a phone module in the boot and a bluetooth module in the armrest
some pre 2003 cars the wiring in the armrest is configured for the phone/handset to be plugged in
bluetooth module can be fitted but some of the wires on the connector in the armrest need swapping about also a couple of wires on the phone module need swapping, its quite straight forward to do
or if you dont have a phone module, because you need the phone module and bluetooth module and mic for it to work, you can buy a later phone/bluetooth module, which has both units combined, but you will need the phone/bluetooth module, bluetooth antenna and the mic
2nd option is easier to fit and supports more modern phones
I have the earlier version and swapped the wires and it works great wth my sony xperia z5 premium
cheers
Joe
