S-type bonnet cable
Old May 6, 2011 | 09:13 PM
Big Patsy's Avatar
Default S-type bonnet cable
Hello all, i am new to this so please understand if i am not doing things correctly. I own a s-type v8 4lt auto 2001, recently my car was dented by a hit and run incident, damage to passenger side front wing and bumper. While i was inspecting car for damage i went to pull bonnet release cable and it simply came clean out in my hand, i did not pull the lever in any way untoward. i was left with cable in my hand which had clearly snapped, cannot open bonnet and insurance company say that the cable snapping was not caused by the impact as they have never heard of such an instance, cable worked fine before the dented wing and now its snapped after the incident . Can anyone advise on my situation as 2 weeks now since incident and still no bonnet opening or repairs and insurance company are not accepting what i said happened, Many thanks
Old May 7, 2011 | 04:31 AM
JagV8's Avatar
Search may get you help but expect it to be very hard to fix unless it broke in a helpful manner and you're good mechanically. Sorry but there it is.
Old May 7, 2011 | 07:01 AM
I think it may be a tough one, have you tried removing the undertray and getting underneath to see if you can access the catches?
What part of Fife do you hail from?
Old May 7, 2011 | 10:40 AM
Gus's Avatar
Gus
On my 2000 the hood has 2 latches and they are located between the lights and the grill. Depending on the grill but you can see the edge of the latch from the grill. It seems that the latch could be opened from the grill with a long and slightly bent rod but I would be cautious in doing that, the radiator is directly behind it.
Old May 7, 2011 | 12:49 PM
Big Patsy's Avatar
Hi bud i live in cardenden,
Old May 7, 2011 | 12:55 PM
Big Patsy's Avatar
Thanks guys for your help, I will carry on till i get it open. But my main question is this, the insurance company say that the hit and run incident could not cause cable to snap .is that the case ?
Old May 7, 2011 | 04:25 PM
It's hard to say, do you have any pictures?
I suppose the cable is on the right, drivers side of the car?
I'm from Leslie originally, small world.
Old May 7, 2011 | 07:14 PM
Big Patsy's Avatar
Correct bud . i got in behind grill and with pliers managed to pull cable. the passenger side popped but drivers side wont budge. i cant see anything past the plastic box which houses the cable, and im unsure what to do next ? Thank you
Old May 7, 2011 | 07:23 PM
Big Patsy's Avatar
Also Norri i can take as many pics as you require bud, so if you tell me which areas or sections etc, it would be a great help. Again thanks for your time
Old May 7, 2011 | 08:18 PM
Gus's Avatar
Gus
Push down on the hood at the same time you attempt to unlatch the drivers side.
Old May 8, 2011 | 08:04 AM
I was thinking pictures of the damage and also of the cable once you get to it.
Old May 8, 2011 | 04:51 PM
Big Patsy's Avatar
Will get the pics bud. the cable has come clean out of the housing and by measuring the lenght it looks like it has snapped around the catch at drivers side. thats the one that has the protective cover on it. as soon as i can i will get pics. an assessor is coming out in the morning to determine if the cable could be snapped due to the impact, as the insurance company say that it is not possible. thanks bud
Old May 9, 2011 | 08:57 PM
Big Patsy's Avatar
Hello all. I have discovered that the cable has snapped just at the latch on drivers side.Removed undertray and drivers side wheel and splash guards but still cant see anything.. HELP.
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
zdrapec
Sep 25, 2015 05:49 AM
