My 2005 S-Type 4.2L V8 started leaking coolant yesterday and found the issue this little hose thing has cut/opening that is almost an inch long. Went to several auto part stores nobody had a replacement as you'd probably already know.
Can anyone help me locate a replacement part online or know the part number ? I've searched with the numbers printed on the hose no luck.
Robinb
close
- Join DateJan 2012
- LocationBC Canada
Liked:182 Times in 138 Posts
Not a very good description, but if you do have the part number, check it out on eBay or Terry's Jag.
Or, see post #23 here:
STR Coolant hoses - Jaguar Forums - Jaguar Enthusiasts Forum
You can also do an emergency repair by splicing in a piece of pipe. Just cut the hose in the middle of the the hole/slice and insert a piece of copper or ABS pipe of roughly the same outer diameter as the inner diameter of the hose past the torn section and clamp it on both ends securely with hose clamps. That at least would get you going until the correct part could be ordered (and sometimes much longer!)
bydand
close
- Join DateAug 2012
- LocationVaduz
Liked:177 Times in 136 Posts
Can anyone help me locate a replacement part online or know the part number ? I've searched with the numbers printed on the hose no luck.]
See the below!
Download the cat and have a look see for the hose and the part number.
If you are feeling charitable, you could even purchase it from them(SNG USA). 10% off remember?
https://www.jaguarforums.com/forum/s...%2A%2A-124677/
Ho Ho Ho!................ Or am I too late for that.
See the below!
