S-Type door latch - Help a newbie with an issue!
Old Mar 25, 2015 | 06:25 PM
Jakeg's Avatar
Default S-Type door latch - Help a newbie with an issue!
Hello all,
I have a 2004 S-Type jag. The drivers door is shut and won't open with the interior or exterior handles.
I pulled back the door panel as much as I could (with the door shut). I can move the rod that connects to the latch module and I can hear the electric lock run for about two seconds, but the latch does not disengage. I moved another rod that opens the exterior handle, still no joy. I pulled the cover off of the passenger side door and if I pull the same rod the latch opens.
Has anyone had this issue, and hopefully solved it
Thanks!
Old Mar 25, 2015 | 07:39 PM
Welcome to the forum Jakeg,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Mar 25, 2015 | 08:59 PM
This may help to some degree....
https://www.jaguarforums.com/forum/s...light=spitfire
https://www.jaguarforums.com/forum/s...ight=door+shut
Old Mar 25, 2015 | 09:28 PM
Jakeg's Avatar
That top thread actually led me to this site
Unfortunately, the door is shut so I have very limited access.
I have isolated the issue to some degree, but without a good diagram or schematic of the latch module I'm flying blind. I'm planning on calling a shop to get a quote. If it's unreasonable I plan on removing the one from the passenger side door and looking for a clue as to how to get it to release.
Thanks!
Old Mar 25, 2015 | 10:01 PM
My advice is to first check with some of the top posting Tech gurus in the S type section.
This was only a quick search by me
These guys will either have experienced it or seen it before and probably have the answers in detail to your query.
Old Mar 26, 2015 | 01:16 PM
tbird6's Avatar
Well it's a tough repair and you most likely will damage your car.
This is pretty close to what you need to do. Not a great explanation I know!
https://www.jaguarforums.com/forum/s...ad-lock-74624/
One other suggestion is to get the JTIS which is free on this site. It's the factory shop manual. You will need it for other stuff too.
Patience is a real key to your repair as you are fishing blind.
If you do get it fixed please post back what you did. This will help the next guy. It was a rare problem but I am seeing it more and more so we need to get the repair figured out so it's not so hard to fix.
Old Apr 26, 2015 | 11:58 PM
xoroniox's Avatar
Hello,
2006 S type 110k miles, running strong.
Last few days, passenger front door will not open from inside or outside. Auto locks are going crazy because of it. I will research and attempt the repair next weekend or so - parts permitting.
Any updates / advice?
Thanks in advance.
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
