s type fuel tank
The 2005 S-Type had just one recall. It was for the fuel tank. Not sure this is your problem so see if any of the attached documents will help? It does mention the problem can cause leaks around the tank seals. Plus they mention fuel odors.
From the TSB:
Q2-Can you tell me more about what is wrong with the vehicle?
A-Investigations have determined that 2005MY North American specification vehicles may be fitted
with a fuel tank that has inadequate thickness around the apertures and/or dimension concerns
that could lead to aperture distortion around the seals. Where the tank aperture sealing is
inadequate it is possible for the On Board Diagnostic leak detection system to sense this and
could result in illumination of the malfunction indicator lamp (MIL) or a fuel odor. Fuel leaks are
most likely to occur only after a fuel tank has been fully filled with fuel.
TSB-R176.
Now the bad thing is the solution is a fuel tank replacement. Don't know if any new tanks are still available or not? Probably not. The recall usually is only good for 10-15 years after it's issued but again that can vary.
From the TSB:
TSB-R176.
Sorry you did mention before the tank was replaced under that recall. I missed that.
Can you get to a junk yard and see if you can find another S-Type to look at?
Do you currently have any codes? You posted about 0174 and 0171 lean codes but those won't be caused by fuel pump issues.
XJDanny
Mar 16, 2019 05:04 PM
cbomb
Sep 14, 2008 12:39 AM
